CaptainDinghy
- May 20, 2016
- 10
jimmbo - thanks for the information above, very good to know. I knew there was a different HP rating scale that occurred in the 80's but didn't know exactly what changed. Interesting that the older 85hp is the same as the newer 75hp.
Would you say the best upgrade as far as power to weight ratio would be going to a 75hp 4cyl or a 90hp 6cyl. Would that extra 15hp offset the extra 100lbs engine weight and still feel improvements on performance?
Generally, do the lower HP 6cyl consume noticeably more fuel than the higher HP 4cyl? All I have right now is a single 6gal pre-mix tank under the splash-well, however I have been contemplating doing some rearranging to get a second tank back there (which of course again means more weight...).
