Best outdrive position for towing and storing?
cube21
Got the new boat, now some basic questions that amazingly I couldnt find a thread about. Ive heard every answer and now I want to know what you guys do.
Whats the best trim position when the boat is being towed and when its stored? (up when towing, down when stored?)
Want to know where to put this bad boy.
also, side question. when the boat electric is off, the key is out, and everything is shut down as far as I can possibly shut it down, should the basic electrical items still work (aka bilge pump, blower, trim, horn.) First boat weve had and this seems wierd that we can still turn on electrical items even though everything is off. Should these work anytime the battery is connected? or is something wrong here...[I/]
thanks all.
-CUBE-
tashasdaddy
Re: Best outdrive position for towing and storing?
towed up with a transom saver, stored as far down as you can, but keep bow high enough the boat will drain rain.
instruments that work with the motor are the only things that should go thru the ignition switch.
if you like you can install a master switch for all accessiories, radio, lights fish, finders, etc, it is preferable to have a bilge pump with a built in float switch, so it will come on automatically, and should be hot wired to battery.
woosterken
there ya go,can't add any more to that! the master has spoken
woosterken
Rocky_Road
woosterken
+1!
This will be the shortest RESOLVED thread, in iboat's history!
Unless...some one jumps in to say that they have been towing their outdrive full down, for the last 20 years...and has never had a problem!
Expidia
Bond-O could have shortened Tasha's wordy response up somewhat. Ayuh :D
