Re: best top side paint help
If the location has already been painted, you need to know the type of paint that was used previoulsy. If it was epoxy or it is gel coat now, you may us several different types of paint.
Epoxy is the best and will outlast one part paints. Many here use Interlux Perfection and get great results useing the method you want to use. I was stuck using a one part paint because my boat had an existing coat of one part paint. It came out well, but from the results I have seen posted, perfection is the way to go.
