I'm installing a FF transducer on the transom of a fiberglass boat (Searay 215EC). I used silicone for the screws mounting the transducer and for the cable, drilled a 5/8" hole (1 1/4" long) through the transom, enlarged the hole from the inside until the outside fiberglass was reached, filled with Marine-Tex and drilled through again, then used the standard 5200 to seal the hole for the FF transducer cable.<br /><br />I found that the 5200 would flow right out after a few minutes. I used wax paper with masking tape on both sides for about 24 hours to hold it in place then took it off to let it finish curing. Seems OK, but it still has about 4+ days left to cure.<br /><br />Questions:<br />It's too late now, but would the fast cure 5200 have been easier to deal with? Any reason not to use the fast cure version?<br /><br />Should I have used something else in the hole? Maybe after putting the connector through the hole, fit a small cylinder around the cable, fill the large area around the cylinder with Marine-Tex first and fill the small cylinder with the cable with 5200?<br /><br />Should I unscrew the transducer and use something better than silicone?
