Better muffs for Alpha One drives?
void7910
Have a mercruiser (4.5) for the first time in a few years. After I drain the block of water, I plan to run it on muffs for AF but the muffs I have don't form a good seal and leak badly. I am worried about losing most of my AF before the engine gets to temp even if pre-warmed.
I currently have this style: https://m.media-amazon.com/images/I/61KtJtwxmmL._AC_UF894,1000_QL80_.jpg
Does anyone have muffs that leak less?
What about these: https://m.media-amazon.com/images/I/81yYtjMIp8L._AC_SX425_.jpg
Lou C
these
Scott06
did you try twisting the rectangles that seal to drive 90 degrees so they are vertical. These are basically the same ones on use on my Alpha gen 2
void7910
Yes they are vertical to match the water intakes. I timed it with the engine off and the 5 gallons empties in about 2 minutes or just less which I am not sure is enough time.
Lou C
I tried several of the rectangular ones I think the rubber is just a bit too stiff, the rubber on the Merc/Quicksilver ones is softer and it seems to fit better plus the clamp allows you to get it really snug.
void7910
Thanks. Crappy thing is I don't live near marinas and Amazon has an inflated price right now. Probably just give up and order them. New-to-me boat winterization fun.
zellerj
Don't see why you have to run antifreeze through the outdrive. With the block and exhaust drain plugs out, take off the J- hose from the bottom of the engine water pump and drain that. For extra assurance with a shop vac on blow - blow out the remaining water. You can pour AF into the engine and exhaust by removing hoses from the thermostat housing. I leave my engine dry and do not use AF to winterize it.
Scott06
I do the same, but if you want to backfill you can do it from the thermostat too.
I take the hose off that delivers raw water from outdrive to thermostat housing. I use a J shaped piece of an old radiator hose off one of my cars as a funnel to pour in AF. If you put the plugs back in you can completely fill if you like, I just use it to rinse out any water or water in sediment in jackets as we are in a very shallow sandy cove
Lou C
that's how I've done it for 20 years, just back fill, it's easier, less stressful and probably uses less AF.
However, the OP has the new 4.5, it has a complex easy drain set up, with lots of hoses..... when I winterized my brother's 2020 4.5 I got a long thin funnel and put it in the vent for the easy drain, just filled it that way. It takes a while because it's a small hole but it does work.
Drcoffee
what I disliked about the round muffs is there is just one source of water, either left or right side. The 8 holes on the outdrive might not allow enough volume to flow in vs the rectangle ones that send water to both sides.
Lou C
I’ve run my V6 Cobra on those for like a half hr with no issues. Runs right at the temp it should, so I think it’s OK….
