weider1717
- Sep 2, 2008
- 315
bought the pontoon it's a 96 toon with a bf50hp honda on it wasn't watering too good then stopped completely so replaced water pump which was toast in pieces.
tested with muffs etc watered good took it to lake did fine but then nearly stopped watering..took it back out the next week to check everything saw nothing wrong no clog checked with compressed air..put it back together watered like it should with muffs.
put it back in water did as should squirting out pee hole like a champ after a couple hr ride looked and it had slowed down to nearly not watering again????????
no clue I know how to change water pumps changed many through the years on my boats I did this correct, even with the entire kit which wasn't needed.
I have no clue the tube was lined up good I checked and like I said it waters strong then for whatever reason I thought to look back and check and it barely was watering under full speed.
