When I approached my boat the other day I heard the unmistakable hum of a small motor. I hav since isolated the noise and it is the bilge pump.
For now I took the post offf the positve terminal and connected it only when I hit the water.
How do these work? I mean I have an inboard switch marked bilge that does cause it ton run when applied... Question is this: Does it power on (normally) even with the inboard switch off as a fail safe in case it needs pumping when you are not there? If so the fact that it is running with no water present means it is stuck in the up/on position? Or has a bad switch? I assume it is a float switch similar to a houses sump pump?
