I have a shower drain sump that has a float switch and an 1100 gph impeller bilge pump. The sump is about 2-3 ft below the in-hull outlet fitting and there's about a 7-8 ft run of 1-1/8" hose between the pump and the in-hull fitting. My question is whether I could reduce backflow to the pump after the float switch cuts off by looping the hose up above the hull outlet about half-way through the hose run. That way, I would think, some of the flow would go out the in-hull fitting, and the rest flow back through the pump into the sump, thereby reducing the amount of backflow. Or would a siphon effect happen and all of the flow go back into the pump anyway? Any ideas on this appreciated.
