fletchermerc1996
- Nov 24, 2009
- 19
Hi guys, hoping you can help!
I have a Fletcher Arrowhawk 18 GTO, which I brought at the end of last year. I need to replace the bilge pump as it's not working.
I spoke to a mechanic at Fletcher the other day and he told me where to locate it, which I've done. It appears that the bilge pump is on some kind of raised fixture, and I was hoping that you can help me with a few questions I have!
Firstly, is the bilge pump screwed onto the raised fixture or attached in some other way, and therefore, how do I detach it?
Is it fairly simple to wire the new one in?
Is there any additional things I need to connect to the bilge pump, like hosing to the base of the hull, or is it just the unit itself that pumps the water out?
Hope you can help! I have little experience with these kind of things!
Many thanks.
Many thanks.
