I changed my battery and neglected to re attach the line that goes to negative battery post (it has a fuse in the line) so the bilge filled up with water. I re attached the line and had to use the manual switch to drain the bilge.  I can not get the auto switch to work. I checked the continuity and it's ok.  In trouble shooting I disconnect many wire and now I want to re wire. But I'm a bit thick so I'm attaching a diagram of the components involved, each one numbered. Please tell me which wires (numbers) go where.
Thanks.
			Thanks.
