Birdshot damage aluminum boat
Horton777
Can this be repaired and if so is it even worth it?
roscoe
Welcome to iboats.
Could be repaired, not easily.
Could be patched if leaking is a concern.
Worth it? That would be your decision.
If I was worried about large amounts of water coming in, I would cover it with a thin coat of 3m 5200 and forget about it.
Grub54891
My duckboat has .22 caliber holes in it. The po had simply put ss bolts in the holes with sealer. I bought the thing from him 35 years ago. Gives the boat charter. I still might fix it but it don't leak.
Commander_47
you might just get a brass hammer, and an aluminum or brass block and gently beat those divits flat. If you have little pin hole leaks I would do the epoxy fix as well.
