Goodguy9684
- May 24, 2019
- 6
Ok. This is kind of my last ditch effort for help. Real quick I've been in the Automotive repair field for 20 years almost all with GM. so I am very familiar and capable to diag and repair mechanical devices......but I have truly met my may and have been brutally humbled by this current problem.
I've got a 2010 Ebbtide Bowrider with a Mercruiser MPI 5.0. This thing has ran flawless since we bought it used 3 years ago. I decided that after 3 years of use it was time to do some PM service over the winter.
New Cap, Rotor, Wires, Plugs, Fuel filter oil and filter, impeller. All factory Mercruiser replacement parts. OEM everything.
And this is when my nightmare began. For some unknown reason I have no spark on Cylinder #1 and Cylinder #2 has spark on start up then after about 10 seconds it goes dead as well. All the rest of the cylinders fire on point.
I have triple checked all my work. Checked all grounds. Battery voltage - 12.5. Changed coil, ignition module. Put the original cap and rotor on....still same problem. Purchased a 2nd cap and rotor kit still same problem. Tried the old wires....same problem. Check resistance on new wires. All are within spec. I've went step by step through the service manual diag chart. The harness and all connections are good. Did a wiggle test of harness while running.......no change.
I've been beating my head for a week now and I've never come across an ignition problem like this. For the life of me I can't figure out how I developed this problem just by doing basic preventative maintenance.
I'm only left with one idea and that is there's a problem with the ECM. But I'm still not 100% convinced that is the problem.
Can anyone provide any assistance or suggestion. This is actually my wife's boat and she is dying to go out on it....she calls the boat " My Happy Place" and usually it is but right now it's my living hell. I'm usually pretty good at figuring these things out but I have to admit this one has me beaten.
