this problem is killing me. 1991 115hp V4 johnson. idled rough and would miss badly sometimes killing it. So i dissassembled and cleaned the carbs. they looked really clean so i put them back on. Fired it up and now it runs even worse, barely runs, idle fluctuates wildly and when i pulled the plugs they were fouled badly oily and black and the top of the cylinders were too.
seems to run very rich but i cant see why, i didnt adjust anything and it all seemed so easy. there are no adjustments. I've rebuilt many carbs too. i hooked up a timing light to check spark and it was very consistent.
also the water from the pee hole was cold is that normal? thanks
the manual talks about some air bleed valve as a possible reason but i dont know where that is.
all 4 plugs were the same. and it spits back and will miss at all speeds although less so at high rpms.
