bruceb58
- Mar 5, 2006
- 30,773
Re: Bleeding Surge Brake BLUNDERS - Wheel Cylinder stuck?
As far as not seeing any evidence of leaking brake fluid, that is totally normal. It usually doesn't leave a telltale stain unless you catch it right when it is leaking.
Absolutely. The springs are strong enough to push them back even without undoing the bleeder screw as long as the bores of the cylinder are in good shape.Sorry to be stubborn, but in that case, if I open the bleeder such that there is no pressure in the system, the springs should be strong enough to push the piston of the wheel cylinder back in. Is that a fair assumption?
