i386
- Aug 24, 2004
- 3,548
I'm assuming I'm using the correct term. I have quite a few areas on the bottom of my hull that are cracked like a spiderweb. Some sanding reveals that the gelcoat has come "unstuck" from the fiberglass in these areas.
I have sanded a few of these off feathering back to where the gelcoat is adhering like it's supposed. In a couple spots I've sanded through the fiberglass. I will repair all of these from the inside with fiberglass cloth (10oz probably) and epoxy resin.
My questions:
Should I continue to sand/grind these out? I don't expect to ever have a showroom finish on this boat but I don't want whatever I end up using to flake off in these areas either.
Once properly repaired from the inside, should I fill the outside with an easy to sand fairing compound or (difficult to sand) resin with milled fibers?
My questions:
