acdc96
 - Apr 23, 2013
 - 412
Lately I've been prepping my boat for the water after a long time sitting in my driveway. (5 plus years). I just cleaned and painted the manifolds and risers from rust build up. (Only took the risers off). I started the motor and let it warm up for 30min to check for leaks and fine tune the carb.
When I drained the engine the next day of water only water came out of the starboard side of the block and a small trickle came out the port side. I put a metal coat hanger up into the hole to unblock any debris but it was clear. Both manifolds dumped water perfectly as I expected .
I'm really stumped on this one, the boat and trailer are level. I tried leaving the port plug open when the engine was running but it still would not drain more than a trickle.
Is this normal or do I have a blocked passage in the block?
1987 Mercruiser 260HP 5.7L V8
