Re: blowing bulbs, navigation lights.
Check the volts at the lights. If the volts are over 14 or so, there might be a problem with the voltage regulator. High voltage shortens bulb life.<br /><br />Another thing to check for is loose mounts. Vibration and shock will break the filiment on a burning bulb quick and easy.<br /><br />Fuses are for shortage or over load/draw amperage protection. Blowing bulbs can be from higher voltage that can shorten bulb life but may not be enough amps to trip a fuse.<br /><br />Also make sure you have the proper voltage bulbs in the lamps. A 6v bulb will not last long on a 12v system.
