- Mar 8, 2009
- 43,992
The thermal switch doesn't have anything to do with the gauge. This switch closes once the engine warms up. To test, use an ohm meter and check for continuity across the contacts. When cold there will be no continuity, but when warm the contacts will close. At no time should there be continuity between the pins and the threads on the switch
I would bet your fuse was blowing, because of the shorted diode
