I have a 93 200 efi, with busted block, will a 225 or 250 power head fit on a 200 lower unit?
B bustedblock Cadet Joined Aug 17, 2009 Messages 12 Sep 1, 2009 #1 I have a 93 200 efi, with busted block, will a 225 or 250 power head fit on a 200 lower unit?
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,936 Sep 1, 2009 #2 Re: blown motor Nope as the 225 and 250 are 3.0 liters in this year range and yours is a 2.5 liter. What type of damage do you have??
B bustedblock Cadet Joined Aug 17, 2009 Messages 12 Sep 2, 2009 #3 Re: blown motor There is a hole in the crank case cover on # 5 cylinder. Have not tore it down and split the crankcase to check for futher damage yet.
B bustedblock Cadet Joined Aug 17, 2009 Messages 12 Sep 2, 2009 #4 Re: blown motor What can be done to the powerhead to increase the hp, assuming the powerhead is salvagable.?
Faztbullet Supreme Mariner Joined Mar 2, 2008 Messages 15,936 Sep 2, 2009 #5 Re: blown motor Not much really stock as you are limited due to ECU has no way to increase fuel duration. You can order a adjustable ECU and intake and get some more hp (20+) That engine should be putting out around 220 at prop.
