boat foam?
MikeSchinlaub
Master Chief Petty Officer
now i have a question i was going to replace the foam when i do the floor and the floor is only soft in one area in the back and i was just going to only replace like a 8 long peice of the floor up to area by the wheel and leave the front but replace the foam in the front to from trying to squeeze underneath the front . i guess my question is should i just replace all of the floor or do it where i dont have to remove the bow seats and the wheel etc ?
What? This is too hard to follow without punctuation.
cyclops222
I use closed cell foam sheets from H D and Lowes for decades. Cheap and cuts easily on the table saw or Jig Saw.
brodyg201
Also i have a question for y’all my motor now doesn’t have trim. and i was thinking maybe along the road adding a aftermart trim plate. do any of you have any experience with those . and if so do you recommend them ?
airshot
Power trim and tilt is great when trying to get max performance from your boat and motor, but the after market stuff ain't cheap ! So...how bad do you want to get the absolute most out of your outfit ? How much HP are you dealing with? For the cost, you might consider trading motors for one that has T&T already on it.
redneck joe
I'm in the same 'boat' on a motor i bought for 400 bucks. Aftermarket stops at about 40hp unless go crazy custom which costs. I an buy a used off ebay for about 1200 but do is that juice worth the squeeze? Its got a whale tail on it so id prob just live with it for in between hole shot and top end. I am not after performance just a bit more hp.
