boat is takeing water how to check
Jason sunbird
I have a 88 sunbird 5.7 its takeing on water when in the lake but not with the ears on pug is ok whats the best way to find were its comeing from or what should I check IM a car guy i no the motor
rickryder
Re: boat is takeing water how to check
Check all of your bellows for holes....that would be first.
Mr. Demeanor
iboats.com Partner
You can also take a hose inside the boat and start spraying water around while someone looks for water coming out.
Chris1956
Those Mercruisers have rubber bellows that seals where the shift cable, driveshaft and sometimes exhaust tube exit the hull to the outdrive. Tilt the OD up and check them out. The exhaust bellow will not leak water into the boat, but the other two will.
Steve Mahler
If it is a Sunbird it would be an OMC, but the issue is the same - probably the rubber shift boot is cracked and leaking. Often a very slow leak which is almost impossible to see. But, it needs to be addressed because it will quickly ruin the outdrive - the water will lead to rust in the gimbal or U joints. Plus it could sink the boat.
