Re: Boat leans to the left
All single screw v-hull I/Os and OBs with right hand rotation props tend to lean to port on plane. Prop torque gives it that tendency. Also, the vertical trim tab is for steering torque, not boat lean, although a waaaay out of adjustment tab could cause you to use steering input to correct and that could cause lean (list). The boat should list slightly to starboard with you in it or a typical load. This helps counteract the prop torque. There could also be problems with the bottom that could cause this. Different props can be better or worse too.
Helm adjustable tabs can solve all of this if she is right to begin with. Can also fix things if she is wrong to begin with . . . Smart Tabs can help too, by going with a higher setting on the port side.
BTW, this needs to be moved to the Boat section. Definitely not an I/O issue unless your skeg is bent
