Okay guys the weather wasn't the best but I have some info for ya. First the stats.
Calm seas
Temp 45 degrees F
Wind <5mph
Full fuel-294#
Two persons - 430#
Boat weight with batteries and misc gear onboard 2000#-2200#
Outboard 500#
Prop 17p Mercury rev4
Trim range for my scientific testing was how many clicks from full in to full out(when tilt engaged). Total clicks was around 32-34 with 14-16 being parallel to the opening of the tunnel/bottom of hull.
Anticav plate was at 1.5" above the top of the tunnel opening when in neutral position and the jackplate was set as low as it would go. The tunnel did angle up as you will see in the pictures but the water flow seemed to be parallel with the top of the tunnel so measurements were taken from that point.
Running info.
-WOT best settings-
-Jackplate all the way up(7.5" from top of tunnel)
-Trimmed out to 15-16 clicks
-No tabs
-RPM around 5300-5400(the little digitach was jumping around some. Also the warning horn started beeping at me when at end of run. Might have actually been hitting rev limiter and the digitach was reading kinda low)
-Speed 48mph
-water pressure stayed upwards of 15-20
Cruise info.
Testing was done at 3500 initial rpms and 4500 initial rpms. Both rpms saw an increase of 2-300 when the motor was trimmed out to 15-17 clicks.
Regardless of jackplate position, all positions only allowed for 15-17 clicks of the trim from fully tucked before the boat would slowly begin to porpoise.
Top speed at 4500 test rpm(4800 after trimming) with motor fully trimmed but jackplate all the way down was 34.5
With jackplate at 3" up and above, speed increased to 40mph.
Steering.
Obviously with the motor fully tucked the steering was horrible. Untucking the motor to 15 clicks or so still saw a little more pressure to port required then starboard but nothing I thought was to much. Inducing some trim tabs allowed for more trim and easier steering if needed. After the test runs I was able to find a seastar dealer that had the purge tube for proper filling of the system. There was some air that came out of the system but very very very little. The steering did feel better though after the maintenance. I wasn't able to retest in the water as the rain had started.
Hull issues.
I did not notice any hooks or rockers in the bottom of the hull when measured with a straight edge.
Boat listing
As you can see in the pictures the boat at rest didn't seem to list to port. If so it was the smallest of amounts.
With two men on the boat I had no need to adjust tabs. The boat rode level. With just me in the boat standing right in front of the wheel(offset on console to port) I did have to add a little trim tab to level out the ride. The port side of the boat also carries the hydraulic system for both the power pole and jackplate. I think with better planning of person placement the listing is gone.
Take a look at the pictures and let me know what ya'll think. The two last ones are from my speed runs. I had a 47mph on the gps and climbing ever so slightly but the motor was all the way up and the trim set to a position that one more click out slowly added a porpoise.
Final Thoughts.
With it all said and done I felt much better about the boat. Yes if I trimmed it out to much it would get hoppy but going into it knowing that not all boats can untuck their motors 100%(rooster tails) and that I was getting half of the trim range out of the motor, and also having the understanding that the steering isn't 100% related to proper trim I was happy with the results.
I think I honestly had a misconception of what I was supposed to be doing trim wise and how the boat should be handling. Learning experience for sure.
Boat listing
Angle of tunnel in relation to neutral trim angle on outboard.
Straight edge on bottom of boat for ease of neutral trim placement. Shown here with 14 clicks out from fully tucked.
Outboard at position 0 on jackplate(all the way down) Cav plate 1.5" above top of tunnel.
Outboard all the way up to position 6 on jackplate. Cav plate 7.5" above top of tunnel.
Outboard at position 3 on jackplate. Cav plate 4.5" above top of tunnel.
Boat as it sits in water.
WOT max speed run.
