Boat misters
mommicked
Does anyone use one?Im thinking of installing one and am wondering if a low pressure system would work well enough if I mount the nozzles pointing up 45 deg. or so from the rail.Most affordable,but all the ones I see are for hanging on biminis or hard tops to spray down.Im guessing the high pressure( higher priced ) ones work alot better as far as cooling effect.
Susquehanna Squid
Re: Boat misters
If you go with the low pressure model you will need to hang it overhead.
