Georgesalmon
- Apr 14, 2012
- 1,793
Re: Boat position on trailer
You should check it as 64 said. But if it "tows great" your probably in the right weight ratio on the hitch. What's that rusty looking stuff on your transom? It looks like gav steel but also looks welded to the aluminum so it can't be steel? Don't mean to be nosy but if it is steel you should get it away from the AL. Steel and aluminum don't like each other. Possible source of galvanic corrosion.
