Re: Boat pulls to the right Really bad
yeah i was wrong i puled this from Michigan wheel website :
Will a different propeller correct bad torque action (listing and hard steering)?
Not usually. Most likely it is the result of any of several irregularities in the hull, the steering hook-up or the engine mounting. Steering wheel must be properly located relative to propeller rotation. If an engine has a right hand rotating propeller, steering wheel should be on the right or starboard side. This side normally would tend to lift as the result of torque action and the driver?s weight offsets it. Modern outboards have built-in features in the lower units to compensate for torque. Engine tilt should be such that the prop is horizontal when underway. If it is up or down, the propeller can have a definite pull to one side. See that the engine is at the exact center of the transom and is setting level. Steering linkage should have enough adequate sized pulleys, properly swiveled and with the right cable tension. Check boat bottom for warping, distortion, which could cause difficulty.
