Boat purchase during Northern winter
airshot
Fair market value can be very difficult to establish. Boat values can differ greatly depending on location and extreme changes in weather. For example hat reason, I recommend looking at everything you can, self educate yourself by shopping. After a while you will be able to spot what might be a good deal and what is way over priced to start. If you have any boating friends, ask them to come along. If your looking at larger boats with inboard engines and living quarters, then a survey is a must unless you possess those skills to evaluate that stuff. Smaller aluminum hull out board's are much easier to self evaluate. You will be far more satisfied if you end up overpaying for a really nice well maintained bost , than you will by getting a bargain price on something that needs lots of work to get running. But, you need to get out there and see for yourself what value means.
mr 88
What exactly are you looking at ? Make, model , drive line ? Are we talking 10K or 100K ? Some boats have a reputation for bad transoms , stringers and gas tanks . I/Os have there issues just like some outboard motors . On the other hand some have great reputations , minimal issues and have a higher resale value because of that . For example, if I was looking at a 31' Tiara , straight inboards and it passed the land survey , I wouldn't hesitate to buy it . Now if it's a 21' Bayliner with a OMC outdrive or Force outboard it would need a sea trial . And there are a ton of boats in that class for sale , so waiting until spring is no big deal .
tpenfield
Although the OP has not revealed the make/model, his earlier threads about his search mentioned Sea Ray 320 and Four Winns 348 as possible candidates.
Probably not looking at a Tiara :LOL:
MI CC
Depends on how much you like the boat and how good of shape it is in.
I did this twice last winter. Paid 10% deposit to hold the boat. First boat was in heated storage so I was able to have it surveyed quickly. Survey was good but there were a few things I wasn't comfortable with so I backed out at that point and said I would wait until spring. Boat ended up selling but I was fine with that.
2nd boat was shrink wrapped so couldn't survey until spring and the survey showed quite a few problems so backed out of that one as well. Ended up finding one later in the summer that is much better than either of the first two.
I would still want it in writing you can back out with full refund if something comes up in the sea trial that isn't easily corrected.
Grub54891
We have heated storage in our marina, just where are you at?
I’ve seen a few that have passed surveys, then when the boat shows up on a truck, we unload it and spot things wrong before it ever hits the water. Some aren’t to bad, some require thousands to make right. Nothing against surveyors, but as a mechanic and knowledgeable about fiberglass and structure, be careful. Even poor wiring gets me. I’d start with a compression test of the engines, that can be done while in storage, just remove the seawater pump impeller. Even water systems can be checked while in storage. Look at thru-hull valves and if they work or need to be replaced or re- bedded. Is the engines room clean? Ok, I’ll stop now…..
