Boat ran 6 years ago
Richard Petersen
Re: Boat ran 6 years ago
Most likely all the gas has evaporated in the carburator and the fuel line down to the pump. Possibly the fuel pump diaphram in it ripped in the first few cranks. Choke valve stuck open? If you pump the gas does any wet the inside of the carb or even smell fresh enough?
olbuddyjack
"fuzz nuts" is that furry growth you get on you battery terminal bolts.<br />I agree with cyclops, its a gas problem...<br />Harry, did you buy this boat from Phil McCrackin?
beezee28
Master Chief Petty Officer
Quietcat, me think we all been had by this harold paratestis guy... :confused: :eek:
Phantom17
I thought I saw Richard Hertz from Holden selling this bolt. Call him ****........
TilliamWe
Banned
Harold, there are a lot of 3.0 out there, I am told, just get another! ;) <br /><br /><br />Ahh, thanks for the laugh man! :D :D <br /><br />Has Don S found a new way to blow off steam??????
Luna Sea
We need to know if you're using the recomended oil or synthetic.<br /><br />Also does it have Smart Tabs or trim tabs?<br /><br />This will clear things up for us.
jeff13601
Take off the t-stat housing. Do NOT put the lower unit in the water or hook up to muffs. Start motor and let it run until the temp gauge pegs. Shut motor off and pour ice water into the t-stat housing. This will clean out your engine and will make it run smoothly. Ignore any water leaks after that as they will fix themselves
BigPoppaG
Harry paratestis.................................. :D
Luna Sea
Don't forget to take the drain plug out before launching, that model engine needs water to run at the proper temp.
Boomyal
Originally posted by Big Poppa G:<br /> Harry paratestis.................................. :D
It took someone long enough to come that conclusion. :D
Harold Paratestis
Are you making fun of my name? How rude. I came here for help with my boat, not my surname.
Stings
did you check the wiper blades? tire pressure on the trailer?
jeff13601
I dont believe anyone is making fun of your name. Paratestis is really quite common and everyone has many in their family tree
moderator1
I ain't gonna touch this one...you guys are doing quite well, playing together....
JustMrWill
I heard he got the trailer from Mike Hawk.<br /><br />(sad thing is .... that is my step brothers name...no wonder he wants to be call Micheal!!)<br /><br />-JustMrWill
