Vintage Boat Guy
- Oct 16, 2013
- 162
I have a 20' boat which is built like an open Lyman. What would be a good size engine to re-power it with?
Moved this over here to get some more exposure with engine and I/O peeps. I think the answer to Mr. Danforth's question is that there is no chance of finding parts for that drive.
Cool. Is that what's on your houseboat?Ayuh,.... I believe Marysville Marine, in Marysville Michigan carries 'bout every part for all the Dana/ Eaton drives,...
do those Eaton drives push the transom or the stringers?
That looks like it might be a plywood lap strake hull.
If it is, the motor and drive are probably the least of your problems.
You should pull up the floor and use your awl to check the keel and where the transom and bottom meet for rot.
You will need about 200 HP to plane and 230 to 280 HP for good performance.
I'm also concerned about fuel consumtion.
