Boat Rewiring.
MR nova @#25
I'm planning on rewiring my entire boat real soon. Can anyone recommend a good book to assist ?
Watermann
Re: Boat Rewiring.
Depending on your boat, you may be able to purchase a replacement harness.
GT1000000
Re: Boat Rewiring.
If you have the time and want to save a couple of bucks...go to the Electrical section of the forum and get some of the best help and advice on wiring a boat...start a thread, post up any questions or concerns and the gurus there will have you all set...
Here is a link...Electrical, Electronics, Audio and Trolling Motors
TJS
Re: Boat Rewiring.
If you are looking for wiring and terminals. mcmaster.com and del-city has all you will ever need. I have wires 3 boats already and will be on my third soon. I solder and shrink tube all my ends.
matt167
Re: Boat Rewiring.
X2, and if you really want to go quality, buy 'XL' wire and not parts store PVC cased wire. All available from Mcmaster.
Re: Boat Rewiring.
I have seen other members post links to good books on the basics so I hope someone will post a link for you. The most important thing you will need is a plan as the wiring is simple. I suggest making a list of what you want on the boat remembering there are things that you need like pumps and anc/nav lights then things that will make life easier like lighting and power points. Once you have a plan then theres 2 ways to install the system. One way is to mount everything then follow a wiring diagram and pull the wires one at a time, the other is to mount everything then measure between the pieces or use some old solid core wire to join the pieces together then remove the parts and lay them out on the floor (throw away the old solid core once parts are spaced) then rewire on the floor which is quicker and neater. I normally draw the main wire run on the shed floor in chalk then lay the wire out on the floor so it can be wrapped and installed on the boat as a loom.
