Boat to trailer latches
airshot
Been reading up on the automatic latches that hold your boat on the trailer while you pull up the ramp. I typically boat alone which means loading and launching alone. I have a system that works well, but at almost 76, always looking for easier methods. 16' aluminum SC boat so nothing big and heavy. These latching mechanisms replace the bow stop on the winch stand and automatically grab the bow eye when you drive up onto your trailer. You still use your winch strap and a safety chain for security. The two popular models are " Drotto" and " boat2Ramp", both work the same, just slightly different build qualities from what I have read. My question is....are they worth the almost 350 bucks you pay for one ? Anyone have one, use one or any real life experiences with either one. Thanks in advance for sharing any experience you might have with these.......
redneck joe
No. I looked into those extensively a while back. The two brands , one is a knock off that iirc sidestepped the patent or something.
I emailed both companies about my 82 mariner and the slope of the bow was not correct. Drotto (the original) told me it would not work so if the company said no to selling me something I trust that.
They are more designed for bass boats. Watch the videos and note boat type.
That said, adding steps to the front was a game changer.
I can get the boat easily to a few inches of the bow stop and at 60 can still lean over to attach the strap, then steps out to the ramp to crank up completely.
airshot
Due to the configuration of our ramps if I stepped over the bow and down steos, I would be in knee deep water. My trailer is a roller type, makes getting off super easy, getting it on is super easy...but...keeping it there while I snap the winch strap can be an issue unless I keep the motor in gear to keep the boat from sliding back. Been doing this for years without a problem, but having a latch would be so much easier....if they work ! That is why I am questioning using one if these....do they really work?
redneck joe
I was sold on the idea until I emailed them.
I put my tailgate down so I can stay dry in the winter, summer wet is fine. But then I will need a way to have steps into the truck bed....
I have docks I can use on my lake so im thinking of making a hook of sorts to throw over the hook and manually pull it. I added rear bunks so can thread the needle as it were. Thinking about adding forward bunks as well. Then a motorized winch even tho a small boat. I'm trying to age proof my set up ahead of time.
roscoe
For what it’s worth, maybe for newbies of or people trying to decide on what type of trailer they want to buy, here is my take.
Unfortunately This is one of the downsides of a roller trailer.
I switched to a bunk trailer about 20 years ago.
The bunks are very low and the boat sits down between the fenders. I can launch/load in very shallow water.
It makes climbing into the boat while in the parking lot or my driveway much easier.
I use a long bow line and float the boat onto the trailer, the bunks and side guides center the boat, and the boat stops on the bunks about 10”from the bow stop.
No running the engine.
No trying to reach the bow eye from inside the boat.
No trying to get back onto the dock or climb over the bow onto the trailer tongue.
Yes, my rubber boots get wet but that’s what they are for.
Sure beats all the hassles I used to have with roller trailers.
airshot
I have owned a number of both both no and roller trailers, each have their advantages and disadvantages. Based on the types of docks/ ramps we have in my area, I have found the roller type work much better for my loading style. Have tried floating and cranking up and it takes longer and more effort for this 76 yr old. The system I now have works well, is quicker than others even when n they have multiple people. Just thought the latch device would be even faster....if they work..
redneck joe
Have you experienced bunk slicks? Effort wise about the same as rollers. I currently have rollers.
airshot
Neighbor has them, but had to cut them smaller as they were to slippery.
That is the nice part about them, you can adjust the slickness by size
FLATHEAD
I’ve thought about one of those gizmos. A few places I go it’s steep and I drive the boat onto the trailer. If I had rollers I’d probably buy one. I’m fortunate that the launch I use the most has a dock, I have a routine that’s fast and dry.
airshot
Smart thinking....if more people would look closely at their loading and unloading practises, things would move far more quickly at the ramps.
I am one that goes overboard in making my tow vehicle, trailer, and boat as user friendly as possible, so I am quick to get in and out. My current system works extremely well, faster than most, both in and out. I am thinking the latching device would make coming out just a little quicker, saving me a couple steps when loading my boat. If this works, I will work on ideas to make launching quicker. So far, most all that have used them speak highly of the devises.
redneck joe
Dad and I were able to be out in about two minutes. Three when I was learning to drive/back the trailer in.
I'm fortunate to boat on a small lake at a small ramp on weekdays so I can take my time.
I would contact both mugs with a pic of the boat and the bow eye. If it works please please let us know I will drop that 350 boat units in a heartbeat.
airshot
I took a chance and ordered one while on sale. I went with the Boat2Trailer unit....20 bucks off and free shipping. Bow curve could be an issue, but I don't think it will. Retired toolmaker here with access to a full machine shop if needed.
