boat trailer calipers vs auto
Stinnett21
I've worked on the calipers for my boat trailer but never on automotive calipers. Due to the fact that boat trailer calipers are routinely dunked in water I was wondering if the boots for the slider bolts were made more water proof than their auto counterparts. If they are indeed tighter and more robust wouldn't this mean they would need to be lubed more often?
tpenfield
My trailer has HydraStar brake calipers on all 6 wheels. According to the manufacturer's information - the piston, the mounting bolts, and slide bushings are stainless steel.
The caliper bodies are "Dacromet" coated for rust protection, but I have found that they rust regardless, and the brake calipers are partially seized. It may be the slide bolts/bushings.
So, I'm not sure if they are more robust than the automotive equivalents or not. They certainly need to be lubricated more often IMO and experience, as I'll be rebuilding the calipers over the winter.
dingbat
I have Kodiak disc on my trailer.
Started with "Dacromet" rotors and calipers. Switched to KodaGuard calipers when the pistons seized a few years back.
The sliders are stainless and ride inside a rubber bushing. Made it 4 years until the bushings wore enough to trap a bit of moisture. New bushings and a bit of silicon grease made them like new again.
tpenfield
Did you find the Kodaguard held up better? I dunk in salt water a couple time a year. After a couple of years, the HydraStar calipers were not having it.
dingbat
Unless you go with a set of Kodiak stainless calipers, the outside protective coating is meaning less. Both will seize if moisture gets past the piston seal causing rust in the bore.
The outside of the Dacromet calipers held up well. Little rust here and there but nothing worth complaining about. Made it 6-7 years before the piston seal failed (dry rot) and the piston seized. Replaced with kadaguard calipers for monetary considerations only.
New Loadrite trailer came with Knott, zinc plated disc brakes.
We will see how they hold up
Stinnett21
I drove to the boat today and lubed the slider bolts. I applied caliper grease to a Q-tip and lubed in the inner part of the boot that squeezes the bolt and lubed the bolt also. Should be good to go. I have UFP/Dexter DB35s galvanized only but I'm in fresh (Kentucky).
tpenfield
Fresh water should be fine. You can always test the brakes (disc brakes) by disconnecting the electrical to the trailer and backing up a slight grade. Probably a good thing to do now & then, if you don't trailer often.
The tandem trailer that I had for my 24 footer had a great set of brakes . . . 7 years of salt dunking and they still worked well. I just don't remember what brand they were :unsure: .
