boat wants to burn out
i have a 1991 starcraft fish ski, with a 4.3 mercruiser and a alphaone out drive. just put in new motor and have had outdrive off and split several times in past 2 weeks, boat runs and drives great except for the fact it want to run up on rpms once in a while, always under a load(while i am trying to get out of the hole or plane out, or at high Rpms and speed), have been told its the prop(that the rubber is bad), but i cant turn it by hand, when its off out of the water and in gear( any info will help greatly thanks to all that give me info
Howard Sterndrive
Re: boat wants to burn out
try another prop
If you ever can turn a spun prop hub with your hand, you don't need a boat.... just swim with the waterski rope tied to your waist :)
big fat guys like me can sometimes get them to slip by jumping on the prop blade...sometimes
not exactly the answer i am looking for, would, like to know if there anything else that can cause my problem and if u can tell conclusively if a prop hub is getting bad
Howard Sterndrive
what answer are you looking for?
$50 dollar prop not exotic enough?
It's the answer everyone dreams of.
You want a 12 page dissertation outlining every possible cause of your symptom?
Put the spare prop on and go try it. If that doesn't fix it, we'll give you the next most probable cause.
i hope its the prop, but wondering if there is anything else that could be disingaging, and causing it to rev out of site and act like it came out of gear
there is a new coupler plate between the motor and the outdrive, so i am hoping it is not that, had to replace because the person that owned boat before me tried to take motor out without pulling motor away from outdrive shaft and bent old coupler plate
and other than trying to spin prop, is there any other way to tell if a prop hub is bad?
180shabah
did you realign the engine after the new coupler was installed?
Poor allignment will burn one up quick.
Get some of your wifes favorite nail polish and mark the prop. Go run the boat under load, when the RPM's shoot up, shut it off and check the marks, if they no longer line up, prop hub is bad. If they do still line up, we need to look elsewhere.
What condition is the prop in? Dings, chips, nicks.....
HT32BSX115
I had a similar thing happen to my previous boat. (A 1966 Mark Twain, 150 Mercruiser ....{dad bought it new})
I was running around the lake and it appeared to "slip" a couple of times at high speeds.
The next week went back to the lake and when I put it in gear, it made a slight "zzz" sound and acted like it was out of gear (whilst in-gear)
The engine coupler is bolted to the flywheel on the crankshaft. It's basically a rubber "dough-nut" with an aluminum splined hole in the center that the steel drive shaft "yoke" to the drive slides into. If the engine is not properly aligned (or the coupler is 39 years old like mine was) the aluminum splines wear out.
When I pulled the engine it looked like someone had put the coupler on a drill press and drilled out the splines!! They were gone! mis-alignment will cause it directly in relation to how mis-aligned it is. (the more mis-aligned, the faster you destroy the coupler)
For this reason (and a few others), Mercury suggests checking the alignment every 100hr or once a year. (which ever is sooner)
Your discription sounds a LOT like that. It's very common. You need to pull the drive and have a close look at the bellows, U-joints, and splines. You'll need to flashlight and you may not even be able to see all that well into the coupler.
If the coupler has indeed failed, the engine has to come out to replace it.
Cheers,
Rick
HT32BSX115
If that's really the case, the previous person probably didn't align the engine properly or align it at at all....
Some people think it's ok to use a drive yoke to do the alignment. Sometimes it works and sometimes it doesn't.
prop is in far condition, and had a boat shop set in and align the motor, but when i puschased boat prop had wrong nut on it and no locking washer for nut, like someone just threw prop on there
and what prop do i want, i have a 19.6 ski fish fiberglass boat with a 4.3? (and do all mercruiser props fit all mercruiser outdrives?):confused:
180shabah
alphas, and bravos (not the B3) use the same hub on the props so they are interchangable 'ish
You still have to watch overall diameter and rake, don't want the blades whacking the case or the torque tab.
Gary H NC
Did you ever mark the hub and prop and see if it stayed aligned after a test run?
thanks for info , greatly ap:)pricitated
