boat wont go fast
fastbasssboat
ok everybody thank for your help we got the boat fixed when i had it in the shop in late feb early march i had no spark i hand a new computer controler put on 813 dollars and the place i had do is a pretty big boat repair shop well you would think that they knew what they were doing but come to find out they dont they had 2 wires on the computer crossed to the 2 coils and that was the problem all along it took a small town boat mechanic and a book and 2hrs later and we had it fixed took it out on the water and shes flying againi cant thank this guy enough for fixing somebody else screw up but i know now where to take my boat and who to trust sopeople a word of advice dont listen tobig time boat repair shops because you might run into a sitiuation like mine
marinemech1
Re: boat wont go fast
check sync and link...pay particular attention to throttle valve sychronization (make sure they are all opening).
Im assuming it went faster before and noone has changed prop etc.
Wayne
trimmers
Dirty or possible gummed up fuel filter? Maybe the check valve in the primer bulb? Can you attach a different portable fuel tank straight to the motor and try it, bypassing any filters and fuel lines you have installed? I always start with fuel and dig dipper from there.
kenmyfam
Have you done a proper spark test with a spark tester to see how much of a gap it will jump ??? Which plugs are black and which are the tan color ??
fastbasssboat
all new fuel and fuelfilters seperate tank doesnt do anything differant
fastbasssboat
done a spark check and fine the 2 that dont do anything is the tan the other for are like black
Clintimania
My boat did this a few years ago and I needed a new power pack on one side. I dont know if that is the right terms or part names.
