arks
- Nov 7, 2002
- 1,947
Re: Boating the Upper Chesapeake
Maybe splash a little AF into any bilge area that might see rainwater.
FWIW, I just drain the potable water tank and heater- no AF. That stuff tastes bad and can be difficult to flush. I also have bypass valves at the water heater (makes winterization easier).
The 'dangerous' part of this process is remembering to open the valves before firing an engine. I keep a piece of paper attached to the helm keys to remind me. At this point it's automatic for me to open things up when entering the cabin.
That would be the pump-out or holding tank port.I also pumped some through the head thru hull fitting..... (name is escaping me right now)
Yeah, you need to get some AF in there. The good thing is that the A/C system doesn't need to operate. Just locate one of the the A/C thruhulls (suction or discharge, doesn't matter) and pump AF thru until it comes out the other end. Check out this video: http://www.liboatersclub.com/home?view=article&id=82I didn't do anything with the A/C because its currently not working. (control board maybe?) instead they installed a small window unit which I think will be coming out. Although, now that I think about it, I may head back over and pump some through just in case I can repair/fix it.
I think you've got everything covered.Is there anything that you think I may have missed? Trying to get over there for the day Friday to work on it some more and I can work on anything you suggest!
Exactly!Rob, just out of curiosity, why leave the seacocks open, just to make sure that there isn't any water trapped in them?
Yes, and not just in the winter. I keep all of my seacocks CLOSED when not onboard for more then 24 hours. Very cheap insurance. You know the other 34 Silverton on Pier 6? Well, a few years ago it sank at the dock because one of the engine intake hoses slipped off. OOPS.Also, by your comment, I assume that you would close them if you are leaving the boat in the water? Could you explain the reasons behind this?
Hey no problem Brandon. I'm happy to help.Sorry, I am just always trying to learn more and more and it makes it easier when I understand the theory behind it! Thanks again for all the info you share with us, it is very much appreciated!
