Boiling Eggs
CN Spots
Re: Boiling Eggs
Boil, let sit for 5-10 min, grab one w/tongs and run under cold water for about 20 seconds and peel as soon as it's cool enough to hold. I've noticed it's easier if they're still kinda hot.
BF
Re: Boiling Eggs
for farm fresh eggs that often don't peel well anyway, hold the boiled egg in your hand and hit it on the "equator" with a butter knife hard enough that the edge of the knife breaks the shell and goes in 1/8 to 1/4" or so... then with your hands, break the 2 halves apart. The yolk will stay with one of the halves. Then take the butter knife and stick it from the broken edge down along the inside of the shell, and go all the way around, just make sure to keep the shell fragments to the outside.... then the egg part will plop out onto your plate, and you'll be holding an empty 1/2 shell. Do the same with the other half, and viola... hard boiled egg without needing to peel. Once you get good at this, you can do it with soft boiled eggs without even breaking the yolk... then you can just plop the egg parts right onto toast.
This was the tried and true method at my grandparent's farm, where fresh eggs were the norm. Usually someone at the breakfast table would ask "Are they good peelers?"... and if the answer was "no" the butter knives would start swinging.... Now when we get bad peelers, my kids say "do that knife thing"... You can do an egg in about 10 seconds.
Bass Man Bruce
Re: Boiling Eggs
Now , if you got eggs in your fridge and some are hardboiled and some are not, just spin em like a top. The cooked ones will spin and the raw ones will fall over.
Just so ya know!:rolleyes:
proaudioguy
Re: Boiling Eggs
This is super technical stuff. I am looking for a way to cook eggs where the egg shell comes off easily without sticking to the egg itself.
Here is how my wife does it now - - She puts the eggs in a pot of cold water, brings it to a boil, removes from the heat and lets sit for 15 minutes. The eggs are cooked perfectly but when you go to take the shell off chunks of the cooked egg come off with the bits of shell.
How do you do it?
She's overcooking the eggs. You only need to hard boil them until they are hard. If you keep them in much longer they are hard to peel. Even if you turn off the heat they will keep cooking unless you get them cooled down pretty quick.
aspeck
Re: Boiling Eggs
And if you want to tell if the egg is spoiled before cooking/breaking, put it in water. If it sinks, its a good egg. If it floats, its a bad egg ... gasses trapped inside the shell from the spoiling process cause the egg to float.
So don't eat the floaters!
tswiczko
Master Chief Petty Officer
Re: Boiling Eggs
Boil them in the microwave:D
Then you won't have to peel them:D:D
But you'll spend a lot of time cleaning the microwave:mad:
