PiratePast40
- Mar 21, 2009
- 1,734
Re: bonding transom
You've got several questions going on and people have different opinions. I did like most people and laminated with CSM and resin. I used screws to hold 2 pieces together until they cured. I then removed the screws and added the third layer of ply the same as the first. After each layer, I also did the best I could to make sure the voids left by the screws were filed with resin. I think that part is pretty common. I happened to use PL premium as bedding since it's relatively dense, dries hard, and is adhesive. Some people prefer a resin mix with filler (cabisol, resin and other filers to make peanut butter). I will caution you about any thick adhesive - it may be much thicker than you imagined - somewhat like taffy. Either buy a high quality, ratcheting calk gun or be prepared to cut open the tube and use a putty knife to spread it. I wouldn't mix resin for placing the transom until the bedding is in place since it may take longer than expected.
I rough cut the transon plate hole and then precut and driled 2 x 4's and other pieces of lumber to use as clamps. here's some pictures:
I'm certainly not the first to do it this way and other people have some techniques that are just as effective. Just hoping to throw out some detailed steps and hope they help.
