Bonding wire Volvo sx-m
Knottyd
Where does the other end of the bonding wire that runs from the top corner of the pivot housing go? I took it apart a while ago and am embarrassed to say that I can’ t remember where it goes. It has a 1/4-20 screw on both ends.
Thanks
Horigan
My bonding cable has an intermediate tab that goes to the bottom of the lower steering bracket (very bottom), then continues to a tab on the gimbal.
Knottyd
Thanks for replying to my post. On mine I have 1 cable that connects to the water inlet hose clamp then runs to bellows clamp to exhaust bellows. Then from there it runs to the transom shield bracket on the very bottom then to the gimbal ring and to the trim cylinder on port side. There is another cable on the starboard side that runs from the transom shield bracket to the starboard trim cylinder. The one that I am conf about is about 10” long with tabs at both ends. One end connects to the back inside corner of the pivot housing. It’s the other end that puzzles me.
Sorry for being so long winded just wanted to make sure I was clear.
Thanks so much
