sutor623
- May 23, 2011
- 4,089
Okay guys, I have been talking to a few guys about props for my setup. 1986 16' Starcraft Fishmaster Aluminum (Dry Weight 610lbs.) and 1967 Mercury 650 65hp motor. Current prop is 17P aluminum. I think the diameter is around 11", which seems small to me. Rake is probably 0 degrees. It is definately an older prop, and needs to be replaced soon. Clocked in speed-wise around 35mph (although that is GPS and there was some wind that day) and not quite sure of RPMs but I am ordering a tach soon. There were two of us on board, 6 gallons of gas under my console, our seats are about middle of the boat, one battery in the back, and two all the way up front just to give you an idea of weight distribution.
Here are the issues that I am having. Hole shot is okay, not sure if I would pull up a skier or not, but I will soon see. Top speed to me seems great, but the main issue that I am having is "hull hop" where when I hit 3/4 throttle the bow starts skipping up and down to where I have to throttle down big time. Water was like glass. I trimmed the motor one hole at a time, and the only time it would stop doing it was with the motor all the way down. It seems to me like this will increase drag a bit as it is forcing the front of the boat down pretty hard.
So questions are, would a "whale tail" be a good thing to add onto the lower unit? Should I just be happy that the boat sits down when I trim it properly? Would increasing the rake or diameter of the prop change this issue at all? Thanks fellas, I am new to the prop game.
