Re: Bow of Aluminum Starcraft hopping at WOT.
Alright fellas, thanks for all the input. So here is what happened this weekend. I had my dad on board and we headed out. I have a bit more weight in the front now as I have added the fishing platform up there. I had a 6 gallons more gas under the console. I trimmed the motor up two holes from the bottom, and the porpoising happened a lot later in the RPM range. I put a tiny tach on, and got great readings up to 1500RPMs and then from 1800RPMs and higher it still read 1800, but that is another issue. I TRIED to get some RPM readings, but didnt happen yet. Anyways I had my dad move up front and sit on the platform, and we did not porpoise at all. speed at WOT was 32MPH, and cruising speed was 25MPH. According to the prop slip calculator, with a 2.3:1 lower unit, 17P prop, and about 10% prop slip the motor is pegged at 5200RPMs, which is right where we want to be. I will try and get another reading from the tinytach this weekend, but as far as I can tell, I am expecting that I want to switch to a 16P 13" Diameter prop, or maybe even a 17P 13". What do you guys think?
