Re: Boyesen Power Reeds
The reason I wanted to wait is because I also run a 20P Raker, but on a starcraft 18ft Deep-V, with a 2.5L 200 with XP heads(basically near the same power out-put as a 150XP-same block, different heads)But yours is the 2.6L, maybe a bit more power on your rig..??<br />My boat weighs in at 2575 full of fuel without me, so 2800 with me in the boat...I also have a 6" jackplate and have plugged the top 2 water intake holes on either side of my lower unit.<br />My boat should have a higher drag ratio per foot of boat in the water.<br />I've run 3 OMC tachs, 2 BRP tachs, 2 teleflex and 1 Faria, and then 2 Beedes..The Teleflex hasn't been a good experience because both had different figures than the BRP tachs, which were un-noticable in any difference. The BRP is in the dash to stay.<br />My 20P raker ran in the 4th hole at about 5600, it vented in turns, but not bad. with the jackplate, I can get just a "tad" over 5800, with a slip ratio of around 9% on a good day.<br />I have to wonder if the prop was mis-marked 20 and should have been a 22, but then again, the 19 pitch props you ran, match what I have data-wise real close compared to the 20 Raker.<br />I honestly feel like your rig should handle the 20P Raker quite well, and 5100, to me, just doesn't sound right for the boat/engine combo you have, and being up in the third hole to boot.<br />It would be nice to see 5700-5800 with what-ever prop, but your rig should have that.<br />My opinion is, as I think about it...we have 50GPS, the only true known...but beings we have changed tachs, then verified the tach, and figure a conservative 15% slip with the RPM indicated, it points right at a 22P prop...BUT, you said the 19's ran the same R's only slower, and that fits as well, so I can't say it's a 22P.<br />My only thought would be to try another tach at this point.<br />One more question: the Raker you have, does it just have "RAKER" stamped between 2 of the blades in maybe 3/16" letters, or is "Raker" molded into the casting in a fancy fasion???
