I always seem to have water in the bilge after a day in the water so I decided to do a little exploring. I put the boat in the water and took the below video. It’s not great but hopefully you all can tell what your looking at better than me. I did t have a lot of time so I did not experiment to see if the leak changed if the outdrive was trimmed up or turned left or right. It did not change with the engine running or not. Video is taken from the starboard side looking at the transom. Exhaust bellows were replaced in July of 2015. In August if 2013 the upper and lower drive seals were resealed, new driveshaft housing seal kit, new gear housing seal kit, new shift cable, and new shift belows. Any ideas what needs fixing based on my limited video, and lack of further experimentation with drive orientation? I’ll be away from the boat for 5 days so I can experiment further if need be on Wednesday afternoon. Thank you.
https://youtu.be/zNEZAusPGqQ
