5.7 EFI with bravo 3. The trailer switch was removed by a previous owner do limit switch is not the issue I assume. Prior to yesterday the button on throttle operated the trim/tilt all the way up and down. Yesterday I was underway for 5 hours, got back to the ramp and it would not tilt up at all. No click, no nothing. I had to remove the pin and use a ratchet strap just to get it home. At home I checked all wires. All are tight. Removed most and cleaned them up and tested. Still goes down just not up. Disclosure, the resivoir has gotten water in it previously which I found and cleaned and fixed. Also, sometimes before it would also not trim up but if I hit the button enough times it would eventually work. But now nothing. Think solenoids or entire assembly? Thank you.
