marlboro180
- Jun 23, 2009
- 1,164
So my Dad's Toro 8-28 ride on mower gave up the ghost.
It would not start for him, even after a jump from a car battery (he kept going up in batteries to jump it)
When I got over to his place he had it jacked up and a 3' cheater bar pulling on the crank from pulley nut. He said he has gotten it to turn over partially with the bar but it was really hard and "sounded funny" .
I proceeded to pull the spark plug out, and gas came pouring out. Then I checked the oil , presuming he already did, but had not. It was full nearly to the top with gas. hmmmm, that's not good.
Float valve was stuck and hydrolocked the motor, then he yanked it with a big bar few times! What other damage to look for?
I got it to my place and took the head off and the cylinder wall are pretty badly galled. Looks like it could be bored out, but here's my question : Is it worth the cost ? What else does one look for ?
I've seen the overbore rebuild kits for $50, then a bore and rehone. Replacement motor (new is 400) used 75-150.
The last one I rebuilt was a 18hp twin for our case 648, which was a lot of fun, albeit fairly costly, and had to as it is an obsolete motor.
I know there's a few small engine guys around here, what's your take?
8hp briggs "Power Range" model 195707, type 0121-0
