Broken Skeg Yamaha 8hp - need advice
genosy
Hi all.
I have Yamaha 8MSHZ (2 stroke, short shaft, 2001 ) with broken skeg. Want to fix it to have a protection for the propeller.
Looks like my options are either welding or skeg protector. Welding can cause overheating and another set of problems, and I can't find skeg protector for such small engine and also I'm not sure if I have enough skeg left for the screws.
I inclined towards the protector so far (if I can find one). What would be your opinion/advise?
I'm nearby Seattle, Washington - would appreciate contacts of a trusted welder or shop who can help me.
Thank you in advance!
you are over thinking it.
get it welded, go boating
any marina that has a full service shop probably also does skeg welding
genosy
Thank you for your reply.
I've decided to use it as is and look for a spare lower unit.
you do know most marinas offer skeg welding, I personally have had 3 welded over the past 40 years.
