Went outboating today and once we were out there the wind picked up and start drifting my boat towards the weeds near shore. The engine of course would not stay running in gear to get us out of there. So I turned on the motor and presed in the neutral button and started to rev the motor to get it to warm up. (was turned off fighing for a a while) While I was revving it at around 2000 RPM the dang thing kicked into gear and jerked the boat and then shut off. After we finally got it going we noticed we were taking on more water than the bilge pump could empty.
Once on the trailer I noticed the engine mount had broke through the transom of the boat.
It is a 16ft fiberglass boat with an 80HP motor.
Pictures show the damage... HOw much will this be to fix, or is it even able to be fixed? Do they make kits to fix this like a metal plate to place on the outside of the boat once the fiberglass is repaired.
Thanks all.
Thanks all.
