Re: Bunk and Roller Adjustment (formerly blood everywhere)
Thought I would bring this up again. Many new trailers are "Bunk" only. They are built with the large Cypress bunks and have a keen pad at the bow (or a roller). On this setup, the bow kell pad supports the bow of the boat and the Bunks support the remaining boat all the way to the transom. I like this setup as it is easy to load and unload with this set-up. And if you have the guide on uprights, the boat loads center (or nearly center) everytime. With the keel resting on the rollers, you have to be sure that you line the keen up before the boat rests down on the trailer and it is very obvious when it is not loaded straight. Pluss if you are trying to load in low water and happen to get off of the rollers, you will get stratches all along the bottom of the boat along the keel. <br /><br />My boat has plenty of scratches from the original trailer with the previous owners. Fortunatley for me, the guy I bought it from, put an Alunimum Magic Tilt under it with the bunks, and I love it. I will not have another roller trailer!!
