burned right thru hull
fngboater
Re: burned right thru hull
thanks oops thats some good detail there. ill copy that one to the clip board for easy reference. yeah i think ill just worry about the interior side first then do the gelcoat repairs once im not so green. :cool:
well ill be using unwaxed poly resin when i start rebuilding my stringers transom and deck so the gelcoat will adhere to the glass right? does anyone know what color gelcoat i should get to try and match the existing color? its almost like an off white or whatever the color is for a 96 bayliner capri classic
For my sea ray, I was pointed toward spectrum for factory matched gelcoat. check with them, they may have a factory match for your hole
