ericcarr2000
Ensign
- Mar 19, 2010
- 903
Ok as many of you may know I just got my repowered 7.4 running for the first time. I took it to a shop to get the timing & carb all tuned up and the break in procedure done on the cam. They told me that during the tuning that they had done it was running real hot. After I picked it up I brought it home and hooked it up to the muffs and started it. I started to notice that it did begin to run hot... I didn't let it get so hot that the audio alarm didn't go off though. At this time I pulled the impeller housing and noticed that the impeller was shot of course. So I installed another impeller, started it up and noticed it began to run hot yet again. So I pulled the impeller housing yet again and of course it was shot. So I thought ok I'll pull the damn outdrive.. When I did there were chunks of my exhaust flappers there along with pieces of the impellers. I pul the drive on the stand hooked the muffs to it and turned on the hose. I noticed that there wasn't any water reaching the upper part of the drive. Am I missing something here as to why the water wouldn't be reaching the upper?
I hooked the hose to the housing after the drive was off to make sure water was going through it and it is. Somethings stopping the water from even going to the motor.. Any suggestions?
