Can’t find water pump on upper gear case
Tlatham
its a omc cobra and no where can I find a diagram or anything on it open the back cover and there is no pump like every single webpage I seen says so.
alldodge
Not hard to find, you sure you have a cobra?
Impeller is item 24
Tlatham
Yeah I’m 100% sure it’s a omc cobra. But no there isn’t one where it shows in that diagram
alldodge
I used google and searched on "omc cobra parts" and came up with sights
Bt Doctur
could it be a OMC stringer drive? or does it have a engine mounted pump and a thru hull ?
Bt Doctur
Lou C
Or maybe you have the 94-98 joint venture drive that will have an engine mounted impeller.
vasy
Is it Cobra or Cobra SX?
If it is SX, it is in on the side of the engine, nothing in the leg.
HT32BSX115
Howdy,
Welcome aboard!
All the questions can be answered easily if you just reveal your model number! (or post a picture)
"It's a omc Cobra" doesn't help much at all since during the Cobra years, OMC had 3 VERY DIFFERENT drives (and called them all "Cobra" or "King Cobra" etc....)!
Also, have a look here:---> https://forums.iboats.com/forum/engi...ion-for-diyers
It will help for future questions and problems!
Regards,
Rick
Tlatham
thanks all, but I’ve just learned it’s on the motor. Kinda sucks. Anybody know how bad that is to change?
HT32BSX115
Actually it really doesn't "suck".........If it's on the engine, it's likely an OMC (Volvo SX) and NOT a "Cobra"....
Model number?
